Old 12-16-2018, 02:00 PM
PurpleVenom's Avatar
PurpleVenom PurpleVenom is offline
Cobra Make, Engine: FFR MKII - 460 Crate with Cobra Jet heads, 750 Quick Fuel Carb, and Edelbrock Torker II Intake port matched to heads
MSD has a tool card that comes with the rotors that has notches cut out for each type of cap they sell. I had been throwing them away and simply guessed at how far up to bend that tab. I found bending it up too much causes premature wear on the carbon button. So, when you get a new rotor, save that bright yellow/green card, it's handy. I can get the measurements off mine if you need it.
To answer your original question, I have found it normal to see carbon dust in the cap. Word to the wise, keep it cleaned out as this dust coupled with moisture(from condensation or rain) makes a pretty good carbon "glue". This will gum up everything from the cap down to the bushing where it mates to the block. Good luck!
