Old 12-17-2018, 11:14 AM
blykins blykins is offline
Originally Posted by cycleguy55 View Post
Brent:
I appreciate your FE knowledge and experience, and this example only reinforces that.
On a related topic, what would be the rev limit for a 385 series with a similar setup - properly profiled hydraulic roller cam, light but strong rocker arms, etc.? Other critical components (e.g. titanium retainers)?
I would expect the same and it's more than likely easier to get to that result. Studded rocker arms are generally more stable than shaft mounted rockers and there are lots of rockers to choose from for the 385 series.
Biggest help is the cam lobe shape, correct spring pressures, and light as possible valves.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
