Old 12-25-2018, 05:38 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by Danr55 View Post
Have you had the heads and manifold match machined? If the.angles are not the same or you use a different thickness gasket the relationship may not be correct.
Yes, any change will warrant a manifold machine.
Block surface, head surface including angle milling, head gasket type, inlet manifold gasket type.
Gary
