Old 01-03-2019, 03:14 PM
Unique427 Unique427 is offline
Originally Posted by t walgamuth View Post
If your ceiling is insulated and your doors reasonably tight you can do a lot with a small electric heater. YOu just have to keep things above the dew point to stop the condensation.
Visible moisture appears when temperature is within 4 degrees of dew point.
Small electric heater with blower not only heats but will help dry out the air.
I placed a small one in front and one in back that blow air under the car cover just above the floor.
The warm air rises up through the chassis.
Helps dry out collected moisture on metal bits susceptible to rust or corrosion.
Effective when heating the whole garage is not an option.
