Old 01-11-2019, 08:45 PM
pgermond's Avatar
pgermond pgermond is offline
Had the same issue. Was what "hauss" suggested. Bleed the hydraulic clutch and problem solved.... for a time. Two weeks later same problem so I changed out the m/c and clutch slave and presto! No more problem.
Bleeding the circuit is a whole lot easier than futsing around with linkage. I would try bleeding first.
Phil
http://www.uniquecobra.com/
