Thread: Backdraft tires
Old 01-12-2019, 04:21 PM
hauss's Avatar
hauss hauss is offline
Cobra Make, Engine: 427 manowar forged crank roller rockers . BIG CAM.
Originally Posted by bobcowan View Post
Tires are not the problem. First thing to check would be air pressure; 24-26psi would be a good starting point.
Also check your alignment specs, front and rear.
If those check out, start looking for something loose, or broken.
First I would like to say I took a look at your car and I love it! I talked to some vintage racers and they said their car act up at low speeds too, is this normal? with sticky tires ? also 335 35 17 on rear and 255 40 17 on front. everything is tight and in proper working order the only thing is it has not been in the alignment shop but at speed the problems go away other than a little steering wheel flutter in corners handles like a dream.
