Thread: 302 timing
Old 01-13-2019, 03:34 PM
DesertMK4's Avatar
DesertMK4 DesertMK4 is offline
Cobra Make, Engine: FFR 306 Ford Racing Holley carb.
Default Ford 302 timing
My motor from Ford Racing said 12 degrees BTDC at idle and not to exceed 36 degrees all in. The motor has a E303 cam as well. Please check your firing order for a HO engine. Should be 13726548 and NOT 15426378. I was told the E303 is a HO cam and it does not matter what block or carb you may use.
