Old 01-16-2019, 06:09 PM
hauss's Avatar
hauss hauss is offline
Cobra Make, Engine: 427 manowar forged crank roller rockers . BIG CAM.
Originally Posted by pgermond View Post
Had the same issue. Was what "hauss" suggested. Bleed the hydraulic clutch and problem solved.... for a time. Two weeks later same problem so I changed out the m/c and clutch slave and presto! No more problem.
Bleeding the circuit is a whole lot easier than futsing around with linkage. I would try bleeding first.
One more thing I had a helper in the car so I could watch the operation and found the plate that the slave cylinder was attached to was flexing
