Old 01-17-2019, 03:10 PM
DanEC's Avatar
DanEC DanEC is offline
I went in from the side but it's kind of up to you depending on your equipment. I did the install by myself so that could be a factor also. I installed the clutch but left the bellhousing off. If you haven't now is the time to check your bellhousing for runout and trial fit the transmission while it's easy to do so.
ERA 782 Running
