  #166 (permalink)
Old 01-18-2019, 11:02 PM
CompClassics's Avatar
CompClassics CompClassics is offline
Cobra Make, Engine: SAI FIA, 289HP (5-bolt), 48IDA Webers
Looks like a nice build, great color choice as well. What kind of wheel and tires do ERA recommend?
Whenever I do a drivetrain installation on a big block or small block Cobra, the bellhousimg is installed on the engine, the car is on jack stands with the front wheels removed, the hood is as open as you can get it (using an adjustable prop rod from the opposite side you are installing from) and I put the engine in from the side of the car. I do not fully extend the boom of the hoist. I go in from the side because I do not want to fully extend the hoist boom and risk the chance of having too much weight moving around and possibly causing the rear of the hoist to start lifting off the ground and toppling over. When putting the car on jack stands leave enough room for the hoist legs to clear the chassis.
