Old 01-21-2019, 09:48 AM
RockBit's Avatar
RockBit RockBit is offline
Cobra Make, Engine: ERA #812 427/482 FE
Originally Posted by AndrewB View Post
I am definitely going to have to get a drop base bottom for the air cleaner and the expansion tank is going to be REAL close to the hood. I'm crossing my fingers that it clears.
Andrew - When you are figuring out how much drop to use, check the clearance between the air cleaner top and the fuel bowl vents on your carb. I didn’t do this and had to add a spacer between the carb and air cleaner base to remove some of the drop.
There is more curvature in the hood from side to side than it looks like, so you have more vertical room than it appears.
Your car is looking good!
Chris
