Thread: Lsa
Old 02-06-2019, 08:08 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by cycleguy55 View Post
LSA at a Glance
Narrower LSA:
  • Moves torque to lower rpm
  • Increases maximum torque
  • Narrow powerband
  • Increase chance of engine knock
  • Increase cranking compression
  • Idle vacuum and quality is reduced
  • Valve overlap increases
  • Decreases piston-to-valve clearance
Wider LSA:
  • Raise torque to higher rpm
  • Reduces maximum torque
  • Broadens powerband
  • Decrease chance of engine knock
  • Decrease cranking compression
  • Idle vacuum and quality is improved
  • Valve overlap decreases
  • Increases piston-to-valve clearance
Source: https://www.hotrod.com/articles/cams...ted-explained/
More: https://www.enginelabs.com/engine-te...-relationship/
I think these two are mixed up back to front. I agree with the rest.
Gary
