Old 02-07-2019, 12:43 PM
Broadsword Broadsword is offline
Cobra Make, Engine: ERA 289 FiA #009
Default ERA FIA bottom cooling hose
Originally Posted by strictlypersonl View Post
Pete,
I like it! The only thing that gives me pause is the rubber's proximity to the anti-sway bar. Hate to have it rub through. I'll check it out.
Hi Bob,
I see your reply to Pete’s solution for LH inlet water pump 10 years ago...
I’m now the owner of ERA FiA #2009 (in the U.K.!) and I have the same question that birddog asked you regarding an updated hose for RH inlet water pump that will do away with the 90 degree elbow.
What do you recommend for RH pump hoses now please?
Thanks and regards, Martin.
