Thread: oil leak
Old 06-05-2002, 04:02 PM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
No, the oil should not be as high as the oil pan end seals (the "U") if it is not overfilled. Thus, it is most likely coming out of a drain plug or the pan may have a crack in it. You must clean off the underside, then see where the oil is coming from.
