Old 02-12-2019, 03:46 AM
Mrs flatchat's Avatar
Mrs flatchat Mrs flatchat is offline
Cobra Make, Engine: DRB, FORD 302W,T5
Wink
Jaydee --- Ask Mal Wood for a quote (by Email)-- tell him what you have and tell him what you want -- then you can shop around if you need to
* clutch pedal, cable or hydraulic ?
* flywheel 157 or 164 teeth ring gear ? --EFI motor 50oz imbalance ??
* starter type that you have ?
* clutch
* bell housing
* Gear box -recommend - T5 (Type 251) Ford mustang V8, 10 spline input and 28 spline out put, 5th is .63 great for cruising with a diff ratio of 3 - 3.5
* rear mount may change ?
* tail shaft slip yoke and length may change
* speedo drive mechanical or electronic?
* shifter stick and knob
In this regard Mal has everything you need
hope this helps and good luck
