Thread: Oils aint oils
  #22 (permalink)
Old 02-12-2019, 12:52 PM
hauss's Avatar
hauss hauss is offline
Cobra Make, Engine: 427 manowar forged crank roller rockers . BIG CAM.
Default Just saying
Wouldn't you obtain more peace of mind by knowing whether you had a significant pattern of wear, or by getting early notice of that small bit of antifreeze that is tipping you off to a gasket leak? Or just knowing how well your oil is holding up? Why would you just blindly change your oil and flush that valuable information away?
First let me say in spec does not mean fully protected oil. Another is contaminants will be removed. You also should check your radiator fluid for leaks and contaminants at least every oil change.fresh oil will help ring seal and car will seem to run better. yes partly your imagination but some truth too. Not saying your way is wrong just saying my way is better.{peace of mind}
