Old 02-12-2019, 04:17 PM
wanab5150's Avatar
wanab5150 wanab5150 is offline
Cobra Make, Engine: Superformance #2769 Roush 427R Dart Block
Fel-Pro 1487 - 195cc-220cc Exhaust Gasket
PRICE:$26.00
AFR PART #: 6839
QTY:
These are for Roush 427 Afr heads .......look at bottom left...Small block ford 205’s are what you have. WARNING.... back in that era of SPF there were two different headers that came on these cars. One set was for small tube headers for 351... and the others are for AFR big port heads. Make sure which headers you have. If you have headers that have a weld about 3 inches from the port then another about 8 inches down then you have small headers for stock 351’s NOT AFR heads. You can also tell when you remove them..... If the gasket is way smaller than the ports on the heads...they’re not the headers designed for this motor and create a blockage and probably cost you 100 hp at 6k rpm. The good news is that if you have small port headers with the big port AFR heads Superformance sold these before the big port heads were being used (dumb asses) because the Roush motors still run good....they just plug the motor up. I’ve seen many many Roush motors in SPF,s with the small headers and the owners have no idea because they’re redicously fast either way.
E,mail me if I confused you. Wanab5150@comcast.net.
Product Information
Fel Pro #1487 Exhaust Gaskets
AFR SBF 195cc Competition Package
AFR SBF 205/225cc
Tom
I miss my Tazer
