Thread: Brake question
Old 02-12-2019, 05:17 PM
vntgspd's Avatar
vntgspd vntgspd is offline
Cobra Make, Engine: ERA #347
Originally Posted by classical glass View Post
What I've done so far last summer new softer pads, bleed all brake lines several times
When you say you put on "softer" pads, what exactly did you install?
I have the same type of performance that you describe and my first step was going to be a more aggressive pad material coupled with turned rotors. My car stops ok but I can feel the pedal flexing before I get anywhere near lockup. I do have Avons on the car so grip may be higher than average, but still...
My 1969 911 has non-boosted brakes, 12" rotors with 4 piston front and 2 piston rear calipers. It stops SUBSTANTIALLY better than the Cobra although it is about 200lbs lighter.
