Old 02-14-2019, 07:49 AM
66gtk 66gtk is offline
Originally Posted by vntgspd View Post
Mine has a center mount with a threaded aluminum knob. Not sure if this is ERA issue from the 90's or not. This is the standard ERA trunk.
This is pretty slick. Note: If you get the optional rear battery you will not have the room to install like this as there will be shelf behind the bulkhead for the battery. A space saver style like I pictured earlier WILL fit between the shelf and the trunk latch. Just barely enough to keep it from moving around.
