  #26 (permalink)
Old 02-15-2019, 03:15 PM
dave295 dave295 is offline
Cobra Make, Engine: Evans chassis, jag fr. & rear.
Jaydee
On a couple of AU Falcons I've played with and had transmission issues I found that:
One would start and drive normally when cold. Whether I drove 10-15 minutes to the local pub or forty minutes to town. Stop the vehicle for a period of time and it would go into limp mode. Third gear only on restart.
I put a scan tool on it which showed live data. The solenoid valves weren't operating.
I pulled the round input plugs off the trans. cleaned out all the debris and that fixed it.
The second issue was a constant change from third to forth and back (constantly) when cruising at about 90km/h. The scan tool showed tps out of range. Changed that and problem gone.
Both these vehicles are six cylinder models with a smaller but similar trans.
I know this isn't your issue but it might help you a bit.
Dave
