Old 02-16-2019, 11:24 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by strictlypersonl View Post
It doesn't matter, but it's easier to put the bolt in from the rear.
No lube is necessary, since they are rubber bushings. The only requirement is that you tighten the fulcrum shaft end nuts when the car is at ride height so that the bushings are not preloaded.
I'm glad most of us on here do this.
I cringe when I see others not do this correctly.
Gary
