Thread: Gasoline Smell
Old 02-18-2019, 04:01 PM
DanEC's Avatar
DanEC DanEC is offline
Originally Posted by Large Arbor View Post
Thanks Gents.
It seems to be from fuel leaking and then vaporizing on the engine bay or in the intake. I can see a few tiny spots where it leaks through the carburetors so I am going to pull them and take them in for an expert rebuild by a gent who told me this guy I am going to is supposed to be one of the best in the country on rebuilding Holley carbs. I will try that and see if it helps.
Phil
My setup is not too different - a LR 427 intake with two 1850 carbs on it. The exhaust is enough to get a cold shoulder from the wife but if I look down the primary throat on the rear carb about 10 minutes after shutting it down I will see fuel starting to drip from the accelerator pump shooter. That fuel on hot engine parts sets up a real stink that lasts for hours in the garage. I have heat shields under mine which helped somewhat but not a complete fix. I do have my floats set to hold fuel just below the sight ports and Patrick probably has a good point about taking them down a bit more. But I think the main issue is the accelerator pump sitting right above the intake and heat off the intake expanding and forcing fuel out the shooters. I've also cut a piece of aluminum faced insulation and put under the accelerator pumps but it hasn't been a complete fix either.
ERA 782 Running
