Old 03-02-2019, 08:14 AM
olddog olddog is offline
Originally Posted by sideoiler427 View Post
thanks for the input. The motor was bored .30 over and it has a 10.5 compression. Yes is know the only thing that is real is the short block but I have been told not too many around that is why trying to figure the value. It bent a pushrod and broke the rocker shaft on the no. eight piston going to replace the rocker assembly and see if any damage to the camshaft. I want to go in a different direction with the motor and would like to sell this one to offset the cost.
The fact that something broke and the total damage is unknown would make the engine less desirable to many. There is a risk factor. Most would want to pull the engine down and completely inspect it. Those costs would need to be subtracted off of the value it is worth in perfect running order. Plus a little more for the unknown risk factor.
