Thread: Temp gauge
Old 03-09-2019, 05:44 AM
Ron61's Avatar
Ron61 Ron61 is offline
Check the wiring, especially for grounds. If that is OK go to NAPA or some parts store and buy a gauge that you can use in your hand and hook it onto your sensor and see what it does. If it reads OK then you have a gauge problem or a wiring problem at the back of the gauge. If not your sensor could be going bad. By it acting the way it does when you first turn the key on I would suspect a wiring issue.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
