Thread: Float Level
Old 03-10-2019, 06:02 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Doesn't say much for whoever overhauled your carbs, if they can't give you a dry float level a fraction under the final wet level that you can sneak up to rather than having the engine flooding, etc.
4160 side pivot floats are easy enough, top of float parallel to bowl.
I run many of my carbs at "number of flats" down from just a trickle.
I do not set any at factory float level.
I run any carbs with windows at 3/8 up the glass.
Gary
