Old 03-11-2019, 03:14 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
All the rocker gear needs to come off.
Straight edge across the valves, if the valve with the broken spring is down, the valve has kissed the piston, and the valve is bent.
A leak down test will also confirm this.
Then the head needs to come off.
Gary
