Old 03-23-2019, 08:51 AM
66gtk 66gtk is offline
Originally Posted by sracer5 View Post
You guys are wrong ! Upgrade was easy. I used a 100mm paper form I measured and made to relocate and enlarge the holes for the speedometer and tachometer. I then used the paper hole that was aprox. 105mm that came with the gauge to mark the hole position then used a dremel tool with a drum sanding disc to follow the marks.Quick , but dirty. I wouldn’t try it with a leather covered dash , no problem with vinal . I didn’t pull the dash or steering wheel. I spent no more than 3 hours total start to finish. Only downside is that it was messy. The smaller gauges are slightly smaller in diameter , but work fine. I’ll post pictures ! BIG THANKS TO ROCKBIT FOR HIS MEASUREMENTS FROM HIS ERA WITH SMITHS GAUGES. I WAS ABLE TO GET TO LESS THAN A .25 INCH FOR THE TACH AND EXACTLY THE SAME ON THE SPEEDO.
I'll bet it was fun to get all the dust created in the channel on the backside of the dash (: Great rewarding project, though. Much better. Thanks for sharing.
