  #56 (permalink)
Old 03-26-2019, 07:06 PM
Moto One Moto One is offline
Update...
Well we have an axel, same axel we had before with new CVs. They thought the axel cv that failed was because it was not shimmed right. When we asked what the play at full load should be we got a, "well we are not sure," "but if its to tight it will damage the cv's","if to loose it will damage the cv". Our car had only one shim and it pulled the cv apart, like maybe it was too tight at full extension. They sent extra shims. If any one had a clearance/play number please reply. I'll be cross checking the play off the other axel for starters.
By the way, adding a shim will in effect lengthen the axel (shims go on the wheel hub side). Humm? That will reduce spline engagement, won't it? By putting more load at the end of the spline shaft. Maybe that how they break that part.
Mark.
