Old 03-29-2019, 04:34 PM
cycleguy55's Avatar
Originally Posted by Texasdoc View Post
Just installed some new SpeedHut gauges. A new gauge I now have is oil temp. It is plugged into the side port on the Canton pan. I've noticed that when I'm driving the oil temp gauge is pegged cold, but when I stop, it will climb up to the correct temp. I'm thinking that since the pan is down in the air steam, the sensor is getting cooled by the passing air. Do I just need to insulate the sensor? Wrap it with heat shielding?
Which Canton pan are you using? This is Canton's 15-680 9 quart pan, and the sender bung is much higher than the bung on my pan. I suppose it could become exposed if the oil level wasn't high enough and oil wasn't draining back fast enough.
https://www.cantonracingproducts.com...-race-pan.html
Here's my pan, you can see the sender bung low on the front driver's side:
https://goo.gl/photos/LV32eSaJ4uwCyRWY9
Brian
