Old 03-30-2019, 08:40 AM
aeon aeon is offline
Cobra Make, Engine: kmp927
Make sure when you go to the bar that your pcv system installed. Breathers will kick you out.. So run lines from both valve covers and connect them someplace. They no longer run the car on a dyno. Just a visual inspection and photos.
They make a little fitting to connect it to base of the aircleaner if you need a second connection point
