Old 03-30-2019, 03:26 PM
Grubby's Avatar
Grubby Grubby is offline
Cobra Make, Engine: ERA 838
Texasdoc,
Your description of how determine oil level sounds correct.
Look at the pan makers web sight and determine capacity, ie 7 quarts. Then change oil and add the amount of oil, ie 7 quarts. Don't start the engine. Mark the dipstick.
Then start it and add enough oil to make up for oil filter and oil cooler capacity, so that the oil level comes to the mark you made on the dip stick.
With the level determined properly, you shouldn't have a problem uncovering the temp sender.
John
