Old 03-30-2019, 07:02 PM
Horseracejudge's Avatar
Horseracejudge Horseracejudge is offline
Gold Star Contributor
Cobra Make, Engine: B & B Mfg 302 EFI
Hi Texasdoc,
I'm using a Canton 13-600 289-302 Drag Race Eliminator double hump rear sump pan. It had to look like the stock pan for certain class racing. My oil temp is Stewart Warner. My sender is in the remote mount oil filter port. Temp is accurate and very consistent with driving conditions. If you are using a remote mount oil filter set up mount it there. Some remote mounts have a spot to drill tap and thread and some come with ports already tapped and threaded. I'm using an AN fitting coupler that is tapped for a sender in my braided line connection to the remote filter. Nick
