Old 04-02-2019, 08:19 PM
Wisconsin_Snake Wisconsin_Snake is offline
Cobra Make, Engine: Classic Roadsters, 95 EFI 5.0
Originally Posted by CR67rep View Post
Thanks for the advice guys. Put new shocks on it last summer, but the springs are still old. Car was completed in 1996 I think the build started around 1992 so maybe the springs are just junk. I’ll check the frame height and size of the wheel wells though. Thanks!
I am not so sure.... from what I've been told, springs do not wear out... You need to change them because the weight has increased/decreased (i.e. a engine swap).
I still have the same springs on my 57 Chevy and they have not lost any of their compression and the car still sits were it's supposed to, and that's 60+ years.
If you do think one of your springs has gone soft so that the car sits uneven...
Pull both of them out and stand them nest to each other or swap sides.
I'd just hate to see you through money at guessing what to fix...
Perhaps one of the springs is not seats quite right... (This would be the side that sits higher).
Good luck.
