Old 04-05-2019, 07:37 AM
CompClassics's Avatar
CompClassics CompClassics is offline
Cobra Make, Engine: SAI FIA, 289HP (5-bolt), 48IDA Webers
Having done the modifications that Morris suggested, no problems at all with differential oil coming out and filling the catch can. Even running at high rpms the catch can is empty.
It was great that you caught this perfect example of poor engineering and design prior to loosing a very expensive component. As I explained to the manufacturer "what good is it that the gear oil is in the catch can (not to mention the oil that spewed out from the catch can) while the differential is operating, doesn't the gear oil need to be in the differential to maintain the proper capacity for operation?" I find it even more negligent that the manufacturer of the differential had instructed the manufacturer of the vehicle how the differential venting system needed to be installed and the vehicle manufacturer neglected to follow the differential manufacturers directions. As the manufacturer explained to me "there is many ways to do something...", well I guess they proved how to do something........the wrong way.
