Old 04-06-2019, 06:04 AM
tortuga tortuga is offline
Default When disassembling and reassembling an HP carb don’t do this
So I figured it was time to take the mixer apart, clean it and put it back together...which I did, I thought successfully...
A word of caution, these things are set up with no real front to back on the main body when looked at by the casual observer with one significant exception; everything is symmetrical except for the power valve ports between the throttle and main bodies, put the main body on backwards and they are blocked causing all sorts of weird tuning issues...
The main body on an hp outwardly has some female threaded holes on the secondary accel pump side, other than that they look pretty much the same but for asymmetrical power valve ports underneath that need to line up with the asymmetric ports on the throttle plate!
Sometimes you feel like a nut...and no that’s not a “good towel” I think...
Steve H
SPF 1764
Superformance 1764
Built 427W
Aiken SC USA
