Old 04-06-2019, 06:08 PM
Phx Mike's Avatar
Phx Mike Phx Mike is offline
Cobra Make, Engine: Ex owner of a polished Kirkham 427 S/C. Now Cobra-less and driving a mid-engine German hot rod.
Originally Posted by 2bars View Post
I say find a way to put it in the Cobra...you need more power
The R1820 had a displacement of 1823 cubic inches. Bore of 6.125” and stroke of 6.875” (9 cylinders). So about 3.78 times the displacement of my 482. Valve area is 1.85 x that of my FE valves. I don’t know the valve lift but I doubt it is more than 2x the FE and the duration is probably less. So in very rough terms of breathing the valves actually seem a little undersize esp considering peak power was made at 2000 rpm. However these engines had supercharging so quite a bit higher intake charge density. 1000 hp at 2000 rpm.
Only the exhaust valves were sodium filled.
Mike
