Old 04-08-2019, 12:06 PM
1795's Avatar
1795 1795 is offline
I'd be willing to say that you had more horsepower before the freshen-up.
A set of Webers doesn't add horsepower by itself, they usually are down a few peak hp to a good single plane intake with the correct size carburetor. Any lack in mid-range power and throttle response can be cured with the correct camshaft.
Webers sure look cool, but they simply don't have the leg-up on other induction systems.
Brent,
I am not so sure that the prior engine had this much torque. We will find out come June when it gets on the track at Mid Ohio. It will be a good test, some elevation changes, only one straight that you can get into 4th gear on, the rest if the course is primarily 2nd and a little 3rd gear. Appreciate the input.
Jim
