Old 04-08-2019, 12:43 PM
CompClassics's Avatar
CompClassics CompClassics is offline
Cobra Make, Engine: SAI FIA, 289HP (5-bolt), 48IDA Webers
Originally Posted by CSX 4133 View Post
Depending on your Vintage Assoc., SVRA, HSR, etc. the engine specifications may be determined by the time period the car represents. SVRA for instance has a Gold Medallion classification that determines cars to be period correct for their years(s) when they competed. 1795, are you limited in the total HP output in your particular classification and did you have your engine built to meet those guidelines?
The rules governing the "Gold Medallion" cars are very strict, the car must be nearly an exact copy of the original in period car, including components and construction materials. The standard "BP Group 6" rules which apply to 289 Cobra based cars is very forgiving comparatively.
In the BP class as long as you run the proper displacement, conventional electronic distributor, iron heads and an iron block you can pretty much get away with most any other modifications you want.
