Old 06-06-2002, 07:17 AM
dscott's Avatar
dscott dscott is offline
Cobra Make, Engine: Owner, Classic Roadsters II
Snake, The prop valve is for the rear brakes. Run the line from the master cylinder to the prop valve and then back to the rear brakes. The fronts don't require a prop valve so run the line from the master to the "t" or 3 way then to each front brake. Easy as pie!
Don
