  #37 (permalink)
Old 04-10-2019, 04:01 AM
blykins blykins is offline
Originally Posted by Gaz64 View Post
Ah yes, after looking at dyno videos.
More investigation as to the cause of the power falling off, either valve float or ignition system etc.
I would say valve float.
If it were just an issue with not enough camshaft, then the power would just fall off in a curve.
In the last 500 rpm of the dyno sheet, we see the power go up, back down, up, back down, etc. That's a tell-tale sign of valve float. I would say that the engine needs a little more valve spring seat pressure.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
