Old 04-17-2019, 03:11 PM
twobjshelbys's Avatar
twobjshelbys twobjshelbys is offline
The altitude is costing you maybe 50HP. I had dynos from sea level and in Loveland and that was all it cost. You can get a 50hp variation from run to run and from day to day depending on temp/humidity. Additionally, unless you spend a lot of time at the red line on a straight track, you won't notice 50hp. If all you are looking to do is make up for the altitude I think you're chasing something that won't be noticeable to you. If you start adding 100+hp, sure, it'll snap your neck harder, but it will also probably turn it into a monster, and it can become something you might not like to drive as much. Like I said, at 500rwhp, my car was too much. For that reason I still will, when I return to the Cobra market place, be more mindful of a small block car.
Be careful what you ask for, you might not like the answer since going back will be costly.
Tony
CSX4005LA
