Thread: Brake question
Old 04-18-2019, 10:26 AM
classical glass classical glass is offline
Default Brake problems
[quote=66gtk;1458025]What chassis number is your car? what wheels do you have?
I have owned several ERA cars and they all stop very confidently when properly setup. I suspect many (like a few I've had) are improperly set up. Some are never right from the start. You may think you have all the air out and the balance bar setup, but you may not. Did you also replace all the rubber lines from the reservoir to the MCs? Hard line from front to back as well as front and rear brake hoses? Depending on the age and miles (lack of use) these areas may all need to be addressed.
Chassis # 823, 6 pin knock off all new SS braided hoses, new 7/8 master, dot 4 brake fulid, speed bleeders vacume blead and pressure (break pettal) calipers were checked out at a local break clinic rotors turned etc. There isn't, much left. The break pedal is rock hard and oh yes new softer brake pads.
