  #31 (permalink)
Old 04-26-2019, 05:38 PM
MKS427's Avatar
MKS427 MKS427 is offline
Cobra Make, Engine: FFR MkIV 427
Originally Posted by Jdata View Post
Actually that's torque argument and low RPM is he weak one. Why? You have a car that weighs 2200 to 2400 lb it doesn't take much to make it move. Your gear multiplication. Typically for starting line ratios you're looking around at 2500 lb of a ratio of 8.75 (first gear + rear gear)
First gear x rear gear.
That said, it is very subjective based on what each individual prefers. You must consider trans gearing, tire height, and what you are willing to tolerate for cruising RPM.
I run a 3.08, 17" tires, TKO 600 w/.64 OD, 1600 RPM at 60 mph.
