Old 04-28-2019, 03:16 PM
1795's Avatar
1795 1795 is offline
It might not be the filter, but rather the oil cooler line connections. Make sure that they are snug. I was having some problem with mixing steel fittings (AN to NPT) with aluminum fittings on the lines. They expand at different rates and may loosen when heated. Make sure that the AN to NPT fittings are aluminum if your AN fittings are aluminum.
