Thread: Brake question
Old 05-04-2019, 06:25 AM
patrickt patrickt is offline
Originally Posted by Jerry Clayton View Post
Change the lines front to small master --------
I see from your first post you already turned the rotors, bled everything, and replaced the pads and master cylinders and worked with the balance. I agree, change the lines. Maybe there's a crimp or something in them that you can't see. Other than changing the calipers themselves I think that's all of the components. If you replace every component and an otherwise known-to-be-reliable brake system still doesn't work, then I would put it on a flatbed and send it up to the boys at ERA and just tell them you're stumped. It happens.
