Old 05-06-2019, 04:10 PM
john chesnut john chesnut is offline
Thanks Lee.
The passenger foot box is as long as the drivers. I made a compartment in the front of it for the battery. I'm using a Dyna Batt small dry cell battery. It's very light. I've used this battery in all of the cars that I've built and I've never had a problem starting any car.
I quickly set the car on scales at the end of today. The only things not on the car that will change the weight are the 2 side mirrors, fuel, and coolant. I have final spring adjustments to do but I'm pretty happy with the initial readings.
I worked on the dash today. I have to make a few tweaks to it.
I'm using Harley Davidson Vrod headlights. There isn't enough clearance for standard car lights. Mr Bruce suggested the Vrod lights. I worked on brackets that will allow for both vertical and horizontal adjustments.
