Old 05-06-2019, 07:10 PM
ERA174's Avatar
ERA174 ERA174 is offline
Cobra Make, Engine: ERA 427, 482ci sideoiler
Jim,
I'm not sure what you are looking for with regard to the Jag rear differential. I have a Jag XJ6 rear differential assembly that had the driveshaft cut off about three inches from the rear universal joint. If you are looking for "the rear driveshaft universal joint and flange" which bolts to the flange bolted to the differential pinion shaft, I have one. Let me know if that is what you are looking for.
John
