  #33 (permalink)
Old 05-16-2019, 07:20 AM
patrickt patrickt is online now
OK, fuse out, run a 12v+ line to the pin on the light that originally had the two green wires that you removed, and the G/R wire is now attached back to its pin. When you do that does the light illuminate? If not, and you're absolutely 100% positive that the light works and that you are giving it 12v+ on one side, then that means it is not getting a return path on the other side through the VR. Double check this test as it is important.
