Old 05-16-2019, 07:54 PM
ACHiPo's Avatar
ACHiPo ACHiPo is offline
Cobra Make, Engine: ERA 824 with 470 FE BBM street 427
Some additional data. Not sure what to make of it other than there is definitely a connection to ground on the fuse 3 circuit, and it's not between the ignition switch and the fuse (that tests as open). All tests were made with the battery cut off in the "off" position. The ignition light is out of the circuit.
Testing the right side of the fuse terminals to ground:
1 Open
2 Open
3 0.7 Ohm
4 Open
5 Open
6 1 Ohm
7 0.7 Ohm
8 0.8 Ohm
