Old 05-19-2019, 11:51 AM
my427cobra my427cobra is offline
Club Cobra Member
Cobra Make, Engine: NAF 427
OK. I am now beginning to understand why the Stelling & Hellings air cleaner flow is so questionable.
First, it turns out I was using incorrect info as I calculated the effective area of the S&H filters.
The perforated steel filter sides have only a 28% effective ("open) area, not the51% I had used in my calculation.
And the Speedway air cleaner tops I was using have only a 38% effective ("open") area, not the 51% I had used in my calculations.
Second, the green foam filter is probably a 65 t0 75 PPI (Pores Per Inch) foam which is a "fine" filter foam. Great for particle filtering but not so great for air flow.
So back to the drawing board.
Greg
